LT1 to LS6/1 conversion
Hello I'm currently new to the Camaro Forums and iv been looking into dropping in an LS6 or LS1 into my '95 Z28 to replace my LT1 since its close to being on its last leg.
my question is, can you drop in an LS6 into a '95 F-body with minor to no part replacement.
Advice is welcome. No major mods have been done to the engine or the car so im pretty much running on stock.
Thank you.
Thank you.
Nope... You pretty much need an entire doner car to make this happen. The engine will not clear your hood so you will need to change the nose to a Catfish nose or get a cowl hood. The wiring, heater box, interior, fuel system, braking system, K member, front suspension, possibly the diff will all need to be changed to make this work. You are best off getting a new LT1 or just buying a LS1 car.
Massey
Massey
