LT1/LT4 Tech 1993-1997
LT1 - Can't seperate the block from the 6 speed trans
Old Mar 11, 2011 | 10:17 PM
Swany68's Avatar
Default LT1 - Can't seperate the block from the 6 speed trans
I have a 95 Z28 convert and I'm trying to pull the LT1 out to do a rebuild on it. I have the bell housing unbolted from the block and the bellhousing unbolted from the 6 speed trans. The engine will seperate from the bellhousing about 2 inches and that is it. It will not come out any farther. I am trying to pull it out the top because I don't have a twin post lift in the garage. Please help before I start going mental on this new project car of mine. Thanks!
Old Mar 12, 2011 | 12:23 AM
you need to take the slave cylinder off and get the fork off the bearing.
Old Mar 21, 2011 | 09:57 PM
Swany68's Avatar
That was it!!! Thank you very much!
Old Mar 23, 2011 | 10:01 AM
what no pictures? lol, good you got it and you are quite welcome. let us know how the project goes.
Old Mar 26, 2011 | 11:30 PM
carguylt1's Avatar
I did the same thing almost unhooked the slave but not the clutch forki.
h_d_ryder
Apr 18, 2009 07:43 PM
h_d_ryder
Apr 18, 2009 07:41 PM
78 LTRS camaro
Nov 22, 2007 08:35 PM
thegcdeez
Nov 26, 2005 06:04 PM
