LT1/LT4 Tech 1993-1997
LT1 Camaro trans problem.
Old Nov 2, 2012 | 02:01 PM
Curt705900's Avatar
Default LT1 Camaro trans problem.
Okay so i haven't been on here in a while, and I'm looking at a 1994 Z28 Camaro to replace my RS. But my issue is of what i found out while test driving this camaro is the fact that when i shifted into drive (yes its an automatic) it took a few seconds before it actually went into gear. So it took about 3 seconds before it shifted into drive after i put it into drive.
Now I'm not so strong on transmission knowledge, but what i would like to know is what would cause that problem, and could it be fixed easily? or would it cost hours of work and alot of money to repair?
Because before i buy this car, i want to know if that's a fixable thing. Help anyone?
Old Nov 2, 2012 | 03:54 PM
Greg08's Avatar
Sounds like a valvebody issue., and could be something small like a checkball / valvebody seperator plate. Maybe leak boost valve. All these things can be done with the car on stands and only requires removing the pan and valvebody. When you order the part from transgo It explains check all placement. You clean the valvebody and then you get Vaseline and dip each ball in it a little to keep them in place and reinstall the plate . But how many miles you got on the z28, because it could probably use new clutch disks(inexpensive) also the 4l60e has a sunshell that is very recommended you replace. Also I have an extra from my rebuild. Mine had gotten rebuilt in he past, and they upgraded it already!H
Old Nov 2, 2012 | 04:04 PM
Greg08's Avatar
Also may be the force motor which is a big solenoid in the valvebody that controls the pressure running through the trans.
Old Nov 2, 2012 | 04:08 PM
Greg08's Avatar
How'd I work oncE In gear?
Old Nov 2, 2012 | 04:27 PM
This could be caused by a shift selinoid or by a pressure problem. For buying purpose assume your are going to need a transmission rebuild to fix it. It the car seller want to prove its something cheap and simple tell them to get it fixed. If not assume the worst.
If the seals in the second gear clutch pack are going bad it will cause this. this would mean a rebuild very soon and may be the reason the car is being dumped.
Old Nov 4, 2012 | 07:38 PM
Greg08's Avatar
I bought my z28 knowing the 60e needed rebuilt. I did it myself. You can to, as long as up haz tools
Old Nov 5, 2012 | 02:12 PM
Curt705900's Avatar
Thanks for the thoughts Gorn, that's what im worried about is that if its a problem where its going to cost me hundreds of dollars or even thousand. Than its probably not worth. However if its something simple then maybe, as long as the seller can get back to me soon.
I do have a relative that knows tranny rebuilds very well. But just out of curiosity, who knows what would have to be done for the rebuild itself? any important seals to worry about? separate plates? ect.
Old Nov 5, 2012 | 03:15 PM
I am not sure there is a simple answer to this question. Everything about a automatic rebuild is important. Your replacing every seal, clutch, wear bushing, and thrust washer in the trans and your inspecting most of the parts you are not replacing. One ripped seal on the reassembly one missed washer and you can trash the transmission. I was trained in automatic transmission repair/rebuild and later GM trained me on the 700R4 (the none computer control version of the 60e). I still have most of the hand tools but I would not try a current trans. There is just to much to keep up to date on. I have a friend that rebuilds 2 to 3 a month part time. I would let him do it for me. Could I do it today, yea, but it would suck to find out after the fact that I should have replaces the shafts in the planet gears because that is a known issue. Your definetly got a better chance of problem free trans if you have someone that has already done a few hundred 60e's.
Old Nov 5, 2012 | 05:27 PM
Curt705900's Avatar
Ahh i see, very cautious work it is, almost if not just as cautious as an engine rebuild. But that's helpful info about it for a long story short.
And i do have a relative who knows how to do tranny rebuilds, and everyone in my town always goes to him. So if i do get this replacement camaro, i'll probably have him take a look at the trans, for a lot less $$$ relatives, gotta love them sometimes.
Oh and Greg08 the car has 180,XXX
Old Nov 5, 2012 | 07:49 PM
Greg08's Avatar
Def rebuild and upgrade if u get
