LT1/LT4 Tech 1993-1997
low oil pressure with 1994 z28 lt1
Old Jun 11, 2008 | 09:15 PM
samtron's Avatar
Default low oil pressure with 1994 z28 lt1
hi all
i have a problem i just bought this car yesterdayall in good codition new radiator new tires new brake and new mainseal and a cam and magnaflows...
so i was driving the cartoday and the motor was cold and the oil pressure was about middle way but after engine started to warm up it droped down to the last line before it hits 0 but if i let off the gas it will go up almost to half way again till i give it a tad bit of gas there is no smoke after start ups cold or hot ......
was woundering if anyone could help me its not leaking anything already been under car to check might be the oil pressure sensor or oil pump ??
ohh and this is my first 1994 z28 lt1 camaro AWSOME AS HELL i still have my old 1994 v6 camaro but tranny is gone
any way thanks all
Old Jun 11, 2008 | 11:55 PM
Default RE: low oil pressure with 1994 z28 lt1
Bad oil pressure gage or sending unit, bad oil pump, low oil. Check the oil pressure with a mechanical test gage.
Old Jun 12, 2008 | 06:47 PM
samtron's Avatar
ty man for posting now one more simple ?,,,,, what is this i got circled in the attached pic it goes from air filter box to some metal thingy then to another tube and then to Tbody thank again
Old Jun 12, 2008 | 07:10 PM
That isthe MAF (Mass air Flow) sensor. Measures the amount of air the engine ingests. The PCM uses this info to determine engine loadand and adjusts the A/F ratio and spark timing as needed.
Old Jun 12, 2008 | 07:35 PM
samtron's Avatar
ahhh so no taking it out lol ok cool im about to go change the oil pressure sendingunit and see if it works thanks man AWSOME forum to
Old Jun 15, 2008 | 08:38 AM
samtron's Avatar
lol dont mean to sound stupid but where is the oil pressure sending unit on this z lol on my v6 it right on side of block above the oil filter but the z28 i cant find nowhere
Old Jun 22, 2008 | 01:18 PM
importmd's Avatar
did you try changing the oil? if its old and broke down you will see low oil pressure. try changing it out for some mobil 1
royco95
Aug 2, 2015 10:25 AM
James Mcclelland
Feb 18, 2014 04:18 PM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
1994btandoz
Feb 12, 2011 09:24 PM
red94
Nov 28, 2006 10:22 PM
