Loosing power under a load
The plugs are good. I have checked them. This was happening before I changed the plugs. I had a new distributor put on it and headers and it was fine for about 5 months then all of a sudden when I gas down on it hard it seems *** it loses power spits and spudders or it is not getting enough gas or maybe too much gas.
another good idea is to replace any vacuum hose (i.e brake booster, pcv valve & hose, ect.) i changed all of mine and the car runs like a champ. check the connections to the MAP, MAF, and IAT sensors. clean your throttle body and make sure the IAC is clean. Honestly, any little work you do the car is gonna be beneficial. 1997 was a while ago, and many parts are more than likely deterriorated.
