LT1/LT4 Tech 1993-1997
loosing oil
Old 04-14-2008 | 10:57 PM
AV95Z's Avatar
Default loosing oil
So i think im loosing the rear main seal in my car... a few drops of oil werent really that big of a deal to me but now its leaking alot more... its coming from in front of the tranny and ive heard of it being the back side of the intake manifold but it was just off a couple months ago and was re-...sealed (RTV'd) when it went back on... I really am not looking foward to dropping the tranny to get to the seal. Also i know if i get the tranny off im going to want to put a new clutch in which just takes more $$$ out of the pockets. Anything else it could be?
Old 04-14-2008 | 11:42 PM
Default RE: loosing oil
Check the manifold again, if not done exactly right it will leak again within a short time.
Old 04-15-2008 | 01:03 AM
Spartan66's Avatar
It would probably help if you tightened it instead of loosened it [8D]
Old 04-15-2008 | 01:07 AM
SpecterGT260's Avatar
Ninja Administrator
if ur oil is too loose try mixing it with a clockwise motion. righty tighty after all
sorry, i really tried not to, it was just too funny (to me...) to not do it.
if ur losing oil the FIRST thing to do is to identify exactly where its coming from. get under the car and try to locate the highest point at which you see oil - check around the bell housing, the head seams, and the intake manifold seam
Old 04-15-2008 | 02:11 AM
Ninja Administrator
dangit spartan...... I wanted that one
Old 04-15-2008 | 02:24 AM
Spartan66's Avatar
i owned you, now give me your T/a
Old 04-15-2008 | 02:43 AM
6v49der's Avatar
I was told that when fixing the intake manifold leak, alot of the manifolds would need machining to not simply begin leaking again. Something with crappy casting and the egr heating up the back, and the gasket just band-aiding the problem.
Old 04-16-2008 | 10:14 AM
AV95Z's Avatar
I havent been able to get under the car cause im stuck at school... hopefully i can get home soon to find the problem/fix it. Ill check the manifold... maybe it didnt seal well enough when it went back on.
Or maybe i can find someone with an oil wrench and just tighten the oil up which should just fix everything[8D]
Old 04-21-2008 | 08:23 PM
95camz28's Avatar
Banned
its the rear main kebouse seal, just drain all the oil, then it wont leak anymore
Old 04-24-2008 | 11:48 AM
Ninja Administrator
red star
03-07-2009 12:14 AM
luvmysccamaro
09-17-2008 03:32 AM
whiteandblack93
08-30-2008 02:42 PM
95camz28
12-06-2007 03:41 PM
Quick Reply: loosing oil
