LT1/LT4 Tech 1993-1997
Lifter making noise.
Old Sep 28, 2009 | 11:50 PM
Nautical's Avatar
Default Lifter making noise.
I started hearing a noise from the driver side engine area.
I think my lifter is making the noise. whats the best way to
fix this problem??
Old Sep 29, 2009 | 11:30 AM
first make sure its a lifter and not a exhaust leak. get a piece of cardboard and see if putting it between the exhaust manifold and yourself makes the noise gets quiter. make sure u dont cover the valve covers. what wt of oil are u using?
Old Sep 29, 2009 | 01:53 PM
If it is lifter noise, the rocker arm may need adjustment, or a pushrod got bent, otherwise the lifter is bad and needs replacement. When is the last time the oil was changed, and what weight oil are you using?
Old Sep 29, 2009 | 09:40 PM
Nautical's Avatar
Im using 5w30. What do u guys suggest
i use. and i did an oil change about 3 weeks
ago. i remember because that's when i installed
the K&N Oil Filter.
Darkdawn79
May 1, 2013 08:12 PM
mjlynch71
Jun 1, 2010 12:06 AM
txrisser
Nov 24, 2008 01:58 AM
87GPLE
Sep 14, 2007 09:32 AM
1995Camaro
Apr 6, 2007 10:59 PM
