LT1/LT4 Tech 1993-1997
Left keys in overnight..
Old 05-05-2012, 09:30 AM
so did a charged up battery make a difference? a really low battery can cause a buzzing sound when you try to start.
Old 05-05-2012, 09:44 AM
wildcat123's Avatar
Its still being trickle charged over at Advanced Auto Parts. Ill go over at noon
Jumping it and trying made no noise.
Old 05-05-2012, 10:08 AM
if the battery is way low then the amps needed to engage the starter may not have been there. the cables will only carry so many amps. i see when you jumped it you left it hooked up for a time, was the car running that it was hooked up to so to charge the battery?
Old 05-05-2012, 10:09 AM
wildcat123's Avatar
Yes the other car was running
Old 05-05-2012, 10:12 AM
ok it should have made it at least try to start. do you have an aftermarket alarm system? you may need to back track and disconnect all the wires to the new stereo.
Old 05-05-2012, 02:39 PM
wildcat123's Avatar
Just got it back from almost 24 hours trickle charging at AAP.
Results:
Good
Volts: 12.39
Measured: 950 CCA
Rated: 720 CCA
Temperature: 76*
Just measured it myself, got 12.5 Volts
Having a problem with the alarm now, went off when i hooked up the battery, and the car won't start. Its going off when i try to start it too. Im pretty sure its aftermarket because when i bought the car the owner told me the previous one put some fancy alarm system in it and there is different tones for the siren going off.. I have a remote, on the screen there is a picture of a car, with half of it cracked/black lined out.. Im not sure if it works.. ill get a new battery for it, but pressing the buttons does nothing. Tried unlocking the doors with the key, still goes off
There also is a switch under the dash cam..
I took the head unit out also, and unplugged the adapter for it
Old 05-05-2012, 03:46 PM
so does it start?
Old 05-05-2012, 03:49 PM
wildcat123's Avatar
Having alarm probs see above
Old 05-05-2012, 04:26 PM
ahh i see you were busy while i was writing. lol. wellll you may want to unhook that dang alarm and get as much of it outa there as you can find. find any paperwork on the alarm
  #20
Old 05-05-2012, 04:28 PM
wildcat123's Avatar
Put a new battery in the remote, and its working.. They keys are faded and i have no idea what they mean or do.. I pressed something on it and the car just died and nothing is coming on lol
Quick Reply: Left keys in overnight..
