LT1/LT4 Tech 1993-1997
left car on
Old 04-16-2010, 02:33 PM
Originally Posted by DarkKnight
I know ive been told that when youre running out of gas the pump works harder and more sediment gets caught up in the filter, cloggy filter is no good, i ran out and i had to change mine, that only had 20,000 miles on it, and it was gross
You're not the only one I've heard say that before, which is why I asked. Since sediment settles on the bottom of the tank regardless, I'm curious where all this filter clogging crud suddenly comes from once the tank is run down close to empty? A couple of years ago, I changed the pump in my old 3rd gen with 116k miles. Other than some small harmless rubber bits in the tank (from the deteriorated pump to sending unit union), my tank was surprisingly clean.
Now, maybe in some rare instances where the car was stored for many years, you could have the dreaded "floating slime". Then as the gas level goes down, the pump could suck that stuff up. I'll give you that one at least!
Old 04-16-2010, 03:30 PM
The pump does not go bad because it sucks up junk from the bottom of the tank. As 69 said, it work that way all the time. The problem is that the pump uses the fuel as a lubricant and a coolant. Low fuel allows the pump to overheat and then die.
kjvforme
05-10-2012 08:45 AM
ExSaint
02-25-2011 09:08 AM
skylinrcr01
08-04-2008 10:30 AM
pureadrenaline
07-24-2006 01:07 AM
Quick Reply: left car on
