left drl
Old Jul 31, 2008 | 01:40 AM
skylinrcr01's Avatar
Default left drl
my left dr wont stay on.. it goes out after about 3 min of running but comes back on after i turn the car off then on. its really weird... anyone who can provide some light into what it might be would be appreciated.
Old Jul 31, 2008 | 10:23 AM
meteoralp45's Avatar
Default RE: left drl
dr?
Old Aug 1, 2008 | 12:38 AM
my bad drl {(daytime running light)blinker}
Old Aug 1, 2008 | 09:27 PM
camaro_burns_all's Avatar
VIP member
Check the fuses, if the are blown or not. And there is a timer there where it should go off after 30 after turning off you car. Check to the timer is broken or not, i think there a timers on those things
Old Aug 1, 2008 | 10:11 PM
okey dokey thanks
Old Aug 3, 2008 | 12:41 AM
does it click really fast when you use it?
Old Aug 4, 2008 | 10:10 AM
nope
Old Aug 4, 2008 | 10:17 AM
rondavis's Avatar
does click at all if not and both start doing the same thing then it is the flasher unit quick fix and about 30 bucks or somthing like that but check fuses first
Old Aug 4, 2008 | 10:26 AM
yea it clicks, it just is kinda temermental. it works for a while then stops. i think it may be a loose connection somewhere
Old Aug 4, 2008 | 10:30 AM
rondavis's Avatar
sounds about right then maybe a bad ground hard to tell tho
kjvforme
May 10, 2012 08:45 AM
ExSaint
Feb 25, 2011 09:08 AM
imcdowel
Apr 16, 2010 03:30 PM
pureadrenaline
Jul 24, 2006 01:07 AM
