Keep dumping coolant
you have a leak somewhere. either you got a bad hose or a crack in the fitting on the radiator or in the new container. can you track the leak, clean and dry everything then fill the sytem and bring the motor up to operating temp, turning it off once in a while to look for signs of a leak and where its coming from. if its what i think it is its pushing coolant out as it heats up and sucking air in as it cools
AnalyzeFaith
Dec 5, 2010 05:54 PM
