just bought a Z28
i dont believe the car has ever been dyno tuned . the exhaust really smells bad of gas until the temp gets above 165 then its not so bad maybe there is another problem but i think the car has 68lb injectors in it. i dont know if any dyno tuners in pennsylvania , im sure there are but i doube any are close to where i live but i would love to have it dyno tuned and programmed correctly. i have another question , the superchager is a paxton sn93, heard bad things about them, there is a small pump mounted on the core support that has two lines that run down to a tube that goes inside the unit , what is it pumping and the "tube" is just loose and sits there i dont know what it is for or if that is normal? and anyone know how to change the oil on the supercharger ? it says to use trans fluid?. i have worked on cars all my life but mostly imports and none were as modified as this car so im a little lost. thanks
