LT1/LT4 Tech 1993-1997
instaling stroker kit
Old Feb 22, 2007 | 05:10 AM
kyleb's Avatar
Default instaling stroker kit
how hard is it to put on? does the engine have to be pulled out? and diy guides or any advise i want to know cause after i get my exhaust an tb im going for it!
thanks for any input
Old Feb 22, 2007 | 01:15 PM
Default RE: instaling stroker kit
About the same as rebuilding the engine, if the job is done right.Yes, the engine nedds to come out.
Old Feb 22, 2007 | 04:43 PM
kyleb's Avatar
s.o.b.!!! im not good enough to do that yet! aghhh man that suxs after the boltons thats realy like the next stiep wouldnt you think what else could i do ?
is the stroker just pistons springs and lifters? what gives you the power?
Old Feb 22, 2007 | 05:09 PM
toml14's Avatar
The stroker is going to require installing a whole new crank and clearancing (machining)the block to accept the longer stroke. You will definately need to pull the motor and expect some downtime unless you are very good and have a shop at your disposal. Changing the pistons, lifters and valve springs are not really required but most people opt to do them since you are that far into the motor you might as well do them. The power comes from the stroke of the pistons.
[/align]
morphine51
70-81 V8 Tech
Feb 25, 2009 09:26 AM
rwing7486
Jul 15, 2008 09:09 PM
buckfever
Dec 15, 2007 10:25 PM
thormotox448
Apr 6, 2006 01:46 AM
thormotox448
Mar 27, 2006 07:47 PM
