LT1/LT4 Tech 1993-1997
im bringin it up.... camshaft, suggestions?
Old Feb 9, 2010 | 10:13 PM
whammer3024's Avatar
ROTM Winner
if you plan on doing LE1 heads later on down the road, then talk to lloyd elliott about your cam as well. he will set one up that will work well with stock heads and work even better after he's had his hands on them.
ps, the cc306 WILL work with stock heads, but its a pretty aggressive cam. i honestly think you'd be looking more in the vicinity of the cc503...i forget the exact numbers on it but i'm sure if you googled "cc503" that you could find plenty of info on them.
also keep in mind all the parts that will be needed to go with a cam swap.
and someone tell me how stroking a motor adds weight...you lost me there
Old Feb 9, 2010 | 10:15 PM
CraZ28's Avatar
Banned
No. You have a clutch. And I think the cam is matched to the heads, that's why you should contact LE or someone that matches the components. Or you can do it like me and piece your build together over time.....
Old Feb 9, 2010 | 10:16 PM
murderd96z28's Avatar
ok so. for now lets just say that all i am doing is cam and headers( cuz the heads will be a long shot) the cc503 cam would be better?
Old Feb 9, 2010 | 10:17 PM
Originally Posted by CraZ28
Dude, he has a T-56!!!!!!
ok, gettin late. scratch that post. lol.
Old Feb 9, 2010 | 10:21 PM
CraZ28's Avatar
Banned
It adds rotaiting mass which is what builds torque. Longer stroke and heavier, stronger components. You don't need to spinn it to the moon when you have torque, you get into the power and clutch/shift it correctly, which by the way cannot be achived on a dino.
ROTM Winner
i believe the cc503 is like 224/230 or something like that...its a very solid cam with stock heads. one of lloyds most common cams is 223/230 if that helps you.
you need to keep in mind that if he's going with LE1 heads, that he's not looking to break horsepower records. lloyd can set him up a very solid cam that works with stock heads or ported heads.
i also wouldn't piece together a build over a couple years since plans ALWAYS change. hell i had plans of a sleeper car...now i went full out 396 2 years later. see what i'm saying?
Old Feb 9, 2010 | 10:35 PM
hell ya i see what your saying, il just have to wait to see for what i want to buy when i have money in my hand then weigh the pros and cons
CraZ28's Avatar
Banned
Well I am keeping my stock 58cc unported, reverse cooled, steam piped, fast-burn heads with 1.94 and 1.50 valves alone, just springs and roller-tip rockers!
Old Feb 9, 2010 | 10:36 PM
hell why not headers mild cam ported intake and nos haha
Old Feb 9, 2010 | 10:41 PM
  #20
ROTM Winner
so you're building a 383, using stock heads, and you're talking to him about torque?
i'm not sure why you felt the need to rattle off all of that information about stock heads...my stage 3 ported heads will still be reverse cooled my friend...and my heads have better springs and NSA rockers as well.
murdered...just talk to lloyd about your plans and goals. trust me, even if you dont' buy from him, he will steer you in the right direction. you don't need a stroker to make beautiful amounts of horsepower
