i think i hate this car
How's your oil pressure? I thought I'd ask before saying anything else (cough...spun bearing)...oops, it slipped out!
You have an automatic right? Next thing you could try is to unbolt the t.c. and run the engine which will either eliminate, or implicate the trans.
I hate to say this, but it sounds like an internal engine problem from the video.
Double check that there isn't anything that is rubbing against the harmonic balancer first though. I don't think anything would be down there, but it is easy to check and doesn't involve dropping the engine to check.
Hmmmm...with the t.c. unbolted, you should have a little bit of clearance and it shouldn't be up against the flexplate. Is it a tight fit?
#20
I can slide the tc back some but something is still touching I think its the little nub in the middle of the tc
