LT1/LT4 Tech 1993-1997
I NEED HELP FAST!! please
Old Oct 29, 2008 | 10:15 AM
gmman200's Avatar
Default I NEED HELP FAST!! please
I have a 1994 LT1 with 88k on it. Ive owned the car for 6 months, always beat the **** out of it, and it akways ran perfect. yestursday i went to get new tires, decided to do one last burnout (ive did many before), dumped the clutch and it bogged down. On the way home the car seemed normal ( i did 90 on the highway), then at the next red light, the idle went down, and once i let the clutch out and went, it was bogging down and won't rev over 3000rpms. Any clue? its not the motor, and im thinking the computer. any ideas?
THanks
Old Oct 29, 2008 | 10:40 AM
02StanGT's Avatar
Default RE: I NEED HELP FAST!! please
It is running like crap now? Do you still have a cat?
Old Oct 29, 2008 | 10:44 AM
gmman200's Avatar
the car is completly stock, so yes it has cats. i tried to diconnect the battery to see if it would reset the computer but it didnt make a difference. this moring i had to drive to school, and it now revs to a little above 4000rpms, where yesturday it wouldnt go over 3400. it doesnt bog as bad as yesturday for some reason but it still runs like crap.
Old Oct 29, 2008 | 11:02 AM
02StanGT's Avatar
Alot of times, if the cat/s plug up bad enough, they cause the car to run poorly and not go past a certain rpm. I highly doubt the computer is messed up. Three areas I would look into, are ignition (optispark is a favorite), fuel delivery, and cats. Is/was the Service Engine Soon light on?
Old Oct 29, 2008 | 11:24 AM
gmman200's Avatar
thanks, il look into it, and the check engine light is not on
Old Oct 29, 2008 | 01:14 PM
Saint_Ali's Avatar
i believe 94 should still have one cat, i think 95 started to use 2, but when i had a cat on mine and it was clogged if i went past 90 on the highway the engine light would come on
Old Oct 29, 2008 | 02:11 PM
whammer3024's Avatar
ROTM Winner
96 was the first year for 2 cats...i agree to look into the cat being clogged...you may also have some sort of vacuum issue. does it start okay? how much gas is in it?
Old Oct 29, 2008 | 07:11 PM
Saint_Ali's Avatar
if you get under the car where the cat is you can lightly hit with your hand you can hear broken pieces moving around, then you know you need a new one, when mine was clogged i could start it but it would immediately die
Old Oct 29, 2008 | 10:06 PM
ROTM Winner
screw getting a new one...gut it and you will be running 6.0s in the quarter!
Old Oct 29, 2008 | 11:15 PM
95slvrZ28's Avatar
1995 Was the first year, but only in California, so those cars are kinda rare, same goes for the 95 3.8 sixxers.
As far as replacement cats go, I recommend Random Technology or Magnaflow metallic high flow cats.
