LT1/LT4 Tech 1993-1997
i need help???
Old Apr 12, 2006 | 05:48 PM
phillycent's Avatar
Default i need help???
i need to know how to put a new starter on a 93 z28 camaro....like i can get it off but...the pipes are in the way....???
Old Apr 12, 2006 | 08:03 PM
94Z28SHAKER's Avatar
Default RE: i need help???
had mine done at the dealership when i first got it, never again, they charged me 700 bucks, said they had to jack the motor up a couple inches to get it off. one good thing tho, if it ever goes bad again they have to replace it for free.
Old Apr 12, 2006 | 08:12 PM
SickSickSick's Avatar
If The Exhaust Is In The Way Remove The Four Nuts That Attach The Exhaust To The Manifolds And Let Them Drop. Should Give You Plenty Of Clearance. Sick
Old Apr 13, 2006 | 03:43 PM
As SickSickSick advised, drop the Y pipe and you will have plenty of room. Liquid Wrench the nuts & studs holding the pipes to the exhaust manifold overnight, as they get rusted up and can break off causing ore problems. There are replacement starters made for the car that are smaller in size than the one the factory put in. These are easier to handle, but make sure you get the mounting bolts to go with them, as the stock bolts won't work.
Old Apr 13, 2006 | 05:37 PM
phillycent's Avatar
yea i can do that...but is'nt that those nuts and bolts hella tight....??....thanks
