LT1/LT4 Tech 1993-1997
How much PSI?
Old Sep 2, 2010 | 03:40 PM
Swimmerboy2112's Avatar
Default How much PSI?
How much PSI should the fuel pump be pushing out on an LT1? I want to diagnose my mysterious starting problem. I searched and got 50psi and 24gph is that right?
Old Sep 2, 2010 | 05:02 PM
1) Per the FSM 41 to 47 PSI engine idling, vacuum line to regulator disconnected. (pump pressure test)
2) With vacuum line connected pressure should drop 3-10 PSI from that noted in step 1. (regulator function test)
3) At WOT under full load, pressure should hold 41 to 47 PSI. (fuel delivery test)
Old Sep 2, 2010 | 07:31 PM
Thank you very much. How about when the fuel pump is priming the engine before startup?
Old Sep 2, 2010 | 07:41 PM
The pump primes the system when the ignition key is in the ON position. If the engine does not start within 2 seconds the PCM turns the pump OFF. In a properly working system the fuel pressure will hold with the engine off for several hours.
Old Sep 2, 2010 | 07:44 PM
Ok cause i think the reason my car won't start is because of the fuel pump not holding pressure. If i try to start it, it just tries to turn over but cant. So i pump the gas while trying to turn it over still nothing. Do that again, still nothing. Try to turn it over for a 3rd time, and just hit the gas once and it fires right up. It drives normal other than a bogging at low rpms. I'm just trying to eliminate all possibilities. And yes the check engine light is on.
Old Sep 2, 2010 | 07:58 PM
First of all the car is fuel injected so pumping the gas pedal accomplishes nothing except to confuse the PCM. By you turning the key ON & OFF several times forces the pump to prime for a longer time and get the fuel pressure up. Before blaming the pump, you may want to check for a leaky injector, as the symptoms are similar.
Old Sep 2, 2010 | 08:10 PM
that was going to be my next guess as to what the problem could be.
