Hooker LT's and True duals V. Stock manifolds and Catback
What are the gains im going to get from the LT's and true duals compared to what i have now? the true dual set up is 2.5 inch pipe with an X pipe and 2 magnaflow mufflers with turn downs? what gains should i see in the 1/4 mile it runs 13.8's now uncapped at the stock Y pipe with a K&N cold air intake and a mail tune from solomon
are you simply looking to improve your et on the 1/4?
do you spin off the line?
If so, a set of drag radials, new gears
then, put the car on a diet and say buh bye to A/C, rear seats, get some skinnies for up front, lightweight driveshaft, windows and ask Solomon to build you a racing fuel tune for when you tank up on racing fuel at the track and load that tune.
I have long tubes but it wasn't to lower my et. I never dyno'd the car but do a search and you will see what some have gained from long tubes.
