LT1/LT4 Tech 1993-1997
Hey I need some help figuring something out
Old Jul 27, 2009 | 11:22 PM
IlovemyZ28's Avatar
Default Hey I need some help figuring something out
Alright basically about 6 months ago my 1995 Z28 camaro blew a headgasket at 73000 miles because it burned through all the water and coolant. It always seemed to run a litttle hot it was always running around 200 to 220 degrees i heard this is because the stock radiator is barely adequate for the car. So 4000 dollars in repairs and a brand new rebuilt engine, its only a few days away from completion. Do you think its about the radiator? and if it is should i get a larger before the car is finished?
Need a reply ASAP
Old Jul 27, 2009 | 11:25 PM
USNAVYORDNANCE's Avatar
I would most definitely upgrade. Not a fan of the plastic on the stock rad. You already spent some cheddah on repairs, whats a few hundred more.
Old Jul 28, 2009 | 12:47 AM
the cars run at 190 to 210 degrees. water pump probly went. i would make sure theres a new water pump on it and a new opti and at the least flush the crap out of the radiator. if u want it to run cooler get a 160 or 180 thermostat and have the ecu/prom(not sure if u have a prom) reprogramed for it. give pcmforless a call and they can set u up.
http://www.pcmforless.com/index.php?...d=44&Itemid=40
IlovemyZ28
Jun 9, 2010 08:08 PM
hensonm1126
Jul 7, 2008 04:35 AM
