LT1/LT4 Tech 1993-1997
Help for a noob...
Old Nov 19, 2009 | 01:03 PM
jsmoltz29's Avatar
Default Help for a noob...
Na na na
Old Nov 19, 2009 | 01:52 PM
Y2K's Avatar
Y2K
Could be the dreaded Optispark issue,do a search here and you'll get tons of info on it.
Old Nov 19, 2009 | 01:53 PM
clyon's Avatar
Could be a fuel pump on its way out
Old Nov 19, 2009 | 02:26 PM
I've had an optispark problem before. It made the engine run crappy since it wasn't constantly firing on all 8 cylinders, which is a typical symptom. It would have to be more of a catastrophic failure for the opti to completely kill the engine. Could happen, but much less likely. I too suspect the fuel pump is going south.
Old Nov 19, 2009 | 02:53 PM
ignition control modual will do that to. so was the filters full of crap. i dump the gas from the filter into a jar so i can see if its getting a lot of stuff or if i just changed a good filter. my truck did what u are saying and it was the pump and the pickup was rusted to $hi&
Old Nov 19, 2009 | 05:15 PM
torque_is_good's Avatar
Joey, a car needs fuel, spark and air
we all could throw ideas as to what it could be. it might be in your best interest to take the vehicle to be tested by a trusted shop. It could be
optispark
coil
ig control module
fuel pump
loose wiring
bad cables
or a host of other items
Bartman51
82-92 V8 Tech
Jun 22, 2013 07:50 AM
insidethreat07
Jun 18, 2008 02:06 AM
Gixxerkid
Nov 6, 2007 04:51 AM
THE ROC
Sep 17, 2007 06:36 PM
GM_Loyal
Aug 28, 2007 12:42 PM
