LT1/LT4 Tech 1993-1997
Help me Get more power
Old Jun 24, 2012 | 08:06 PM
BasicConcepts's Avatar
Technical User
Originally Posted by dlaidoutranger
the only thing you have left to do that would make power would be an underdrive pulley set, but that would only be good for about 5hp, you could gain a couple more hp if you do an a/c delete pulley, but thats about all you have left to do on your motor that would be an easy bolt on, if you want more power you are going to have to start changing internals. in my honest opinion with the facts that you are 16, this is your first car i would suggest leaving it the way it is, i know thats not what your wanting to hear but this is coming from exprience, when i was 16 i owned a couple of high hp street/strip cars and got into alot of trouble with them, i suggest, and again this is just a suggestion, im not telling you to not go all out if thats what your wanting, but just enjoy the car, drive it and find out how it handles and what its limits are and when you know how it handles and reacts like you know the back of your hand, then start with adding more power, the car is pretty powerful the way it is and will take most mustangs so just enjoy now
ac delete pulleys dont free up power. all there designed for is to replace a locked up compressor if you decided not to get another one. an ac compressor not running is the same as the delete pulley, free spinning.
Old Jun 24, 2012 | 10:29 PM
dlaidoutranger's Avatar
true that, but it would at least shed a couple lbs
Old Jun 24, 2012 | 11:39 PM
Norfolk96z28's Avatar
So lets say I do start getting into the more complicated internal parts of the engine, what would he the first thing I should upgrade to increase up?
Old Jun 25, 2012 | 12:32 AM
a good tune can pick up 25hp in some cases. can also get you better mpg at the same time. go to the site i linked to and read some on it. if your serious give solomon a shout and let him know what you have. he can filll you in better than i on what a tune will do for your setup.
Originally Posted by Norfolk96z28
The headers run to a 3inch Y pipe then its basicly straight piped almost to the the rear then it has some muffler with like a downturn. Ill post some pics soon of the z28. Also what does it do to get the computer tuned?
Old Jun 25, 2012 | 12:56 AM
Technical User
cam, rockers, springs, loyde elliot heads, 58mm tb. thats about all you can do with out rebuilding the bottom end and going 383
Old Jun 25, 2012 | 11:56 AM
torque_is_good's Avatar
honestly, the first thing which should be upgraded is your bank account.
once you open the top end it comes down to ....you may as well also do this
if you are going for a cam then new springs and rockers should be done. Why do the valve train without gettng new seats, guides and an overall valve job? Since the heads are off, why not have them flow better?
Old Jun 27, 2012 | 06:05 PM
So basicly unless i want to drop a couple grand i should just get a basic tune up, and maybe get the computer tuned ?
Old Jun 27, 2012 | 07:14 PM
that is up to you
4th gens are a royal pain in the butt to work on. If you're putting in a cam, push rods, springs and rockers then new seals should be installed and then since you are that far into it, yank the heads.
that is just my opinion.
Old Jun 27, 2012 | 07:50 PM
bob97z28's Avatar
PM me dude, im in Norfolk, I have a couple buddies with LTs and LSs.
Old Jul 12, 2012 | 10:09 AM
  #20
I know this is a old post that I made but does anyone know of someone that's turbo'd or supercharged their lt1.?
