LT1/LT4 Tech 1993-1997
Help!!!
Old Feb 6, 2012 | 11:05 AM
My93camaro's Avatar
I'm not sure, my friend that I bought it from is looking that up for me. But I will get the harness on it's way.
Old Feb 12, 2012 | 10:10 AM
SandysLT1's Avatar
The last time my car died while driving the water hose busted and killed the distributor.Took for ever to get it back running.
Old Feb 12, 2012 | 04:12 PM
lt1 xjs's Avatar
Originally Posted by My93camaro
Okay, I replaced the plugs, did a test on the injectors, it was good. Did a compression test and it was less then sixty psi. Could the chain jump? The rockers are moving so it's not broke. Also the tested fuel pressure, it was only 35
If you have spark and fuel it would try and start. Do as Craby suggested and spray some starting fluid in the throttle body. If it tries to fire then the injecters are frozen, try tapping on them or have them cleaned. If it's sat for three years, it's more than likely the injecters.
Old Feb 12, 2012 | 04:29 PM
you did a compression test on all the cylinders? i overlooked that part. 60lbs would indicate that that cylinder has a leaking head gasket or valves are not set right or valve is sticking.
Old Feb 12, 2012 | 04:37 PM
If all cylinders are in reading in the 60 PSI compression range the engine is going to be very hard to get running. One possible thing that could affect compression on all cylinders would be a timing chain that jumped a few teeth, and now the valves are opening and closing out of sync with the pistons. The spark would still be good, but out of time, just like the valves.
Old Feb 12, 2012 | 04:44 PM
pete would that set a 16 trouble code. im thinking yes but not sure.
Old Feb 12, 2012 | 06:13 PM
The PCM determines the crank and cam position according to the low and high res pulses are generated internally by the opti, so as long as the opti is functioning properly the PCM is going to see both signals at the proper intervals and stay happy regardless of the relationship between the crankshaft and camshaft. Other engines that use physical cam and crank sensors would see the bad relationship and set codes. I also suspect that OBDII LT1 engines (96 and up) with a real crank sensor will pick up the problem also
Old Feb 18, 2012 | 04:52 PM
My93camaro's Avatar
Question
So I pulled the timing cover, the timing marks lined up correctly. Timing chain is loose, but that shouldn't cause it not to start. I did get the new harness but haven't put it in yet. Car does not start on ether.
Old Feb 18, 2012 | 05:16 PM
re do the compression test and was it 60 lbs on all cylinders? i keep going back to thinking the opti failed. take the cap off the opti and see what things look like in there.
Old Feb 25, 2012 | 06:57 PM
  #20
My93camaro's Avatar
What are the odds it could be the ignition control module?
