LT1/LT4 Tech 1993-1997
Header and Valve question
Old Sep 19, 2011 | 09:16 PM
Mikey.'s Avatar
Default Header and Valve question
I know these are pretty unrelated, but both are problems I'm currently having: (97 lt1 trans am btw)
Does anyone know the proper valve adjustment method? I'm lost in the sauce on this one, but I want to do it myself.
My driver side header is leaking on the last port by the firewall. The two bolts on that one pipe were very loose, so I tightened them, but I guess the gasket is shot. How hard is it to replace the gasket? (the headers were on when I bought the car) What gasket do you guys recommend? And should I replace the bolts also? Thanks for any help.
Old Sep 20, 2011 | 12:09 PM
percy's seal 4 good exhaust gaskets are the best and easy to put on. heres some info on setting lifters. 4th Gen LT1 F-body Tech Articles
Old Sep 22, 2011 | 08:37 PM
Psycho's Avatar
I bought a new set of bolts and I believe they helped the install go easier as they weren't all rusty and had good corners. I also used the Percy's Seal 4 Good. I got them at Autozone.
Old Sep 22, 2011 | 09:12 PM
torque_is_good's Avatar
Ok, here is the old school method which i still use
remove valve cover
start engine
one rocker at a time, loosen until I hear clacking
tighten until clacking goes away, tighten for 1/3 to 1/2 turn more
move on to next rocker
sam.maeder
Jun 8, 2015 11:16 PM
sc86mc
Apr 25, 2011 08:48 AM
QC97Z
Nov 17, 2008 01:04 AM
BIGMIKE
Aug 31, 2007 06:12 PM
adrenilinjunki
Mar 9, 2006 12:54 PM
