LT1/LT4 Tech 1993-1997
header question
Old Jan 30, 2007 | 09:24 AM
kyleb's Avatar
Default header question
hi all i had a understanding issue with ehaust on my lt1.
i want to have dual exhaust but i think mine is only single!! i found this on ebay and its kinda the way mine
looks like. but this ehaust system say that it has 2 cats but where would the two cats go on that... theres only one pipe going to the muffler??! to do a duel exaust you'd need a y pipe right? or x pipe?
somone plz explain to me!!!
http://cgi.ebay.com/ebaymotors/CORSA...83424640QQrdZ1
Old Jan 30, 2007 | 01:06 PM
Default RE: header question
You are looking at a cat back system. The cats are before the system. The dual cat cars use different plumbing than the single cat cars. If your car has a single cat and you want to use dual cats you will need different exhaust manifolds or headers, and different Y pipes.
Old Jan 30, 2007 | 02:51 PM
kyleb's Avatar
okay thats what i thought, but it was confuseing me,.two cats is better than one would you say? even though 2 cats is more restrictive than one? i want to upgrade the exhause system what should i do?
Old Jan 31, 2007 | 12:25 AM
The cats in dual cat applications are installedbetween the exhaust manifolds andthe Y pipe, each bank having its own cat. In single cat applications, the cat is installed between the Y pipe and the exhaust system. Therefore, all things being equal, the dual cat will flow better than the single cat. 10HP better according to Chevy.
However, if you are going to redo the exhaust and looking for the most power, get a set of headers and Y pipe, high flow cat, and a catback system. Stock exhaust manifolds are pretty pricey and do nothing for power by themselves.
BIGMIKE
Aug 31, 2007 06:12 PM
1bad96Z28
Apr 26, 2007 02:30 AM
RedDragon
Nov 14, 2006 07:15 PM
frankthetank078
Apr 4, 2006 10:35 PM
