Header install on a 4th gen
#57
I may do a header install in a few months... how bad is it really? People make it sound awful lol but ive rebuilt top ends and done head gaskets on 4 cylinders before and i didnt have any trouble with that even when bolts stripped or broke. Is it just time consuming, because i have patience? i guess what im trying to ask is how long should i expect to spend on the swap?
#58
I had no issues with bolt removal from the old exh manifolds
If you are going without egr and AIR then those headers go in easier
Could it be done in a day, sure. But, allow for 2 days in your garage at home because you will be replacing plugs and wires as well since you're right there.
You may also find it a good time to replace the tranny mount
#59
that depends on your capabilities, tools and work area. You aren't going to install just long tubes, you'll need a y pipe as well and then need for it to attach to your aftermarket cat back system (silly to try and use stock system)
BTW my tranny mount is new it was replaced about 2 months ago.
#60
If u do it without a lift, it'll take twice as long and a lot more patience. When I did it, I removed the egr and the AIR, so it was easier. But fitting them is very tight. Tougher at home. You'll need a healthy dose of patience, and time. If your not eliminating the air and egr, things take longer. You get more hp if you remove the emission crap. My runs like a raped ape with only a set of long tubes, a 3" ORY, a custom 3' cat back to a Hooker muffler, a CAI, a chip, and a shift kit. For handling, I went with an entire BMR suspension front and rear with Bilstein shocks, and Eibach springs. Now I can corner using all the power the car makes. The A arms with their new ball joints made a huge difference over stock. The torque arm is a noticeable improvement when launching.
