head gasket
head gasket
my 1994 z28 5.7 l is loosing coolant and I can't find any leaks the oil looks slightly light but no bubbles. Could it be the head gasket and if so instead of replacing it what does anyone think about using one of those fixes you pour into the engine .do they work and what are the long term effects? thanks any info would help.
oil will look like hot chocolate if theres coolant in it. sorta like someone added some milk to the oil. not really a good idea to use gasket saver. can work for the short term but will plug or reduce the effectiveness of the cooling system and heater core.
