LT1/LT4 Tech 1993-1997
Head and Cam info.
Old May 13, 2007 | 09:29 PM
GsusFrk's Avatar
Default Head and Cam info.
Ok so i've been saving money to put a set of heads and cam in my car. I've finally got the money and now that i'm ready to buy. BUTi have no idea what i'm gonna buy... So my father wants me tospend the time to find out why certain heads are made one way and others another. so i've been searching all night for an article that will explain the intricate points of engine heads. Guess what!I'velearned alot about specific heads and what they can make but nothing about heads in general. if anyone wants to explain or point me in the right direction that would be great. I want to make my camaro somewhere between 400hp and 450hp and still be a daily driver. Would Loyd Elliots LE2 set workor would it be to aggressive?? any help would be very much appreciated.
Thanks, Kyle
Old May 13, 2007 | 10:00 PM
Default RE: Head and Cam info.
Talk to Lloid Elliot & tell them what you want to do with your car. They will recommend the proper heads and custom grind a cam to match. They do good work.
IMO head design is a sort of black art, even with computer models. If you interested, give this book a try "Vehicular Engine Design" by Kevin L. Hoag
Old May 19, 2007 | 01:13 PM
camarolt197's Avatar
I have recenty installed a set of off road hooker long tubes on my 97 Z. I had to bypass the EGR and the AIR, I am ready to install the heads and cam. I need to know who I can send my computer to to have the AIR and the EGR deleted to pass an OBDII inspection. any advise would be great.
Old May 19, 2007 | 03:07 PM
It will fail the visual inspection, and the test equipment will query for the egr and not find it and fail it. Same with the AIR. It wil also fail the readiness test (drive cycle).
Old May 22, 2007 | 09:34 PM
coprunr's Avatar
pete , does that apply after you have done the LT4 conversion? if the VIN says LT1 (w/ EGR) and you have the LT4 conversion (w/o EGR) ? of do they just check for EGR ready in the PCM?
jcmstg7
Dec 19, 2009 12:34 AM
camarofreak1990
Apr 21, 2009 04:50 PM
daves96z28
Nov 22, 2007 11:33 PM
o2camaross
LS Series Tech
Feb 17, 2007 10:41 PM
tee
Dec 31, 2004 01:17 PM
