LT1/LT4 Tech 1993-1997
haha wow..differential problems
Old Jun 7, 2010 | 04:12 AM
Dillon5224's Avatar
Wow, now i feel dumb!
well, ive got the M6 so apparently ill love it =)
Old Jun 16, 2010 | 03:13 AM
Dillon5224's Avatar
Well, UPDATE.
I took my car to the mechanic today so he can fix the Ring and Pinion (that was the problem for sure). I am gettin 4:10/4:11s or whatever they are. It should be quiiiick when i get done More updates soon!
By the way, what gears come stock with the 96 Z28 M6?
Old Jun 16, 2010 | 03:53 AM
check the op codes and ull know what you had in the car from the factory. should be a sticker in the glove box or the center console that has a bunch of codes that have letters and numbers in them.
heres a list i found.
RPO Table RPO
Description
A26---Window Glazing, European
AG1--Driver Front Seat, Power Adjuster
AH3--Front Seat, Manual 4-Way Adjuster
AK5--Inflatable Restraint System, Driver and Passenger
AN4--Restraint Provisions, Child
AQ9--Front Seat, Driver and Passenger Recline
AR9--Front Bucket Seat, Deluxe European Style
AU0--Remote Entry Lock Control
AU3--Side Door Elec Lock Control
AX4--Restraint Conversion Seat, Manual European
A31--Window, Power Operated Side
A90--Lock Control, Rear Compt Lid Remote Elec Release
B35--Covering Rear Floor Mats
B4C--Sales Special Service Pkg (Police)
B84--Molding, B/S Exterior
CC1--Roof Hatch Removable Panels, Glass
C49--Rear Window Defogger, Electric
C60--HVAC System AC Man Controls
DD9--Mirror, O/S LH & RH Remote Control Electric Color
DE4--Sunshade, Removable Hatch Roof
DG7--Mirror, O/S LH & RH Remote Control Electric Color
D21--Sunshade, Windshield
D35--Mirror, O/S LH Remote Control, RH Manual Color
D82--Paint Special
FE2--Suspension System, Ride and Handling
FE4--Suspension System, Special Ride and Handling
FE7--Suspension System, Front and Rear Heavy Duty
FE9--Certification Emission-Federal
F41--Suspension System, Front and Rear Firm Ride and Handling
GU2--Axle Ratio 2.73
GU4--Axle Ratio 3.08
GU5--Axle Ratio 3.23
GU6--Axle Ratio 3.42
G80--Axle Positraction
IL2--Trim, Interior Leather (W/AQ9) Pontiac
IL4--Trim, Interior European Camaro
IL5--Trim, Interior (w/AQ9) Pontiac
IPB--Trim, Interior Cloth Camaro and Firebird
IPD--Trim, Interior (w/AR9) European Camaro
IP2--Trim, Interior Leather Camaro
IP3--Trim, Interior Leather Pontiac
JAF--Brake Provisions, European
J65--Brake System, PWR Front and Rear Disc
K05--Heater, Engine Block
K29--Module Powertrain Control, Export
K34--Cruise Control, Automatic
K68--Generator, 105 Amp
LS1--Engine, Gas V8 5.7L, MFI Aluminum
L36--Engine, Gas V6 3.8L, MFI HO
M49--Transmission, Manual 5 Speed OD
MM6--Transmission, Manual 6 Speed OD
M30--Transmission, Auto 4 Speed Electronic
NK3
Steering Wheel, Sport Soft Rim Simulated Leather
NM8--Leaded Fuel System Compatible, European
NP5--Steering Wheel, Leather Wrapped
NP7--Steering Column, EEC Approved
NW9--Traction Control, Electronic
N36--Steering Wheel, 4 Spoke Sport
N60--Wheel, Aluminum Painted
N66--Wheel, Styled Aluminum 17" 5 Spoke Polished
N73--Wheel, Custom Sport Var4 17" (Restricted to Camaro SS)
N92--Cover, Wheel Bolt-on
N96--Wheel, 16 X 8 Cast Aluminum
N98--Wheel, 16 X 8 Cast Aluminum Chrome
PA6--Wheel, Styled Painted 16"
P05--Wheel, Styled Chrome 16"
QA9--Wheel, 17 X 9 Aluminum Painted (Blue Tint)
QB3--Wheel, 16 X 7.5 Steel
QCB--Tire, All P235/55R16 BW
QEA--Tire, All P215/60R16 BW
QFK--Tire, All P275/40R17 BW
QFZ--Tire, All P245/50R16 BW
QLC--Tire, All P245/50R16 BW
TR7--Headlamps, Control Leveling System Automatic
T1G--Vehicle, Military Personnel
T37--Lamp, Fog Deluxe
T39--Lamp, Turn Signal Aux
T43--Spoiler, Rear
T62--Lighting, Daytime Running Delete
T65--Lighting, Daytime Running Export
T78--Headlamp Control, Delete
T79--Lamp, Fog Rear
T82--Headlamp Control, Automatic ON-OFF
T84--Headlamps, RH Rule of Road
T85--Headlamps, LH Rule of the Road
T89--Lamp, Tail & Stop Export
T96--Lamp, Fog
UA6--Theft Deterrent System
UB3--Cluster, Inst Oil Cool Temp Volts Trip Odom Tach
UC2--Speedometer, Inst Kilo Positive Bias
UK3--Electronic System Steering Wheel Acc Controls
UL0--Radio, AM/FM Stereo Auto Rev Music Srch Cass Clock ETR
UM6--Radio, AM/FM Stereo Auto Rev Cass Clock ETR
UN0--Radio, AM/FM Stereo Compact Disc Auto Tone Clock
UQ0--Speaker Sys, 4 Dual Frt Dr Mtd Dual STD RGE Qtr/Shelf
UW3--Radio, AM/FM Stereo Auto Rev Music Search Cass Data Sys
UZ7--Speaker System, 8 Quat Frt Dr Mtd Dual RR Hatch Amplifier
U1S--Player, Multiple Compact Disc
U62--Speaker System, 4 Dual Coax Frt Dual Coax PKG Shelf
U73--Antenna, Fixed Radio
U75--Antenna, Power Radio
VK3--License Plate, Front Mounting Pkg
VL4--License Plate, Rear Mounting Pkg
V12--Cooling System, Power Steering
V76--Hook, Tow
WS6--Performance Package Special
WS9--Model Conversion, Formula
WU6--Sales Package, Firehawk Upfitter
WU8--Sales Package, Z28 SS
W52--Entertainment System Option B
W53--Entertainment System Option C
W54--Entertainment System Option D
W55--Entertainment System Option E (MONSOON)
W59--Entertainment System Option I
W66--Merchandised Pkg, Formula
W68--Sales Package, Firebird Upfitter
W73--Entertainment System Option J
X10--Entertainment System, Option I
X20--Entertainment System, Option J
Y3F--Sales Package, RS Camaro
Y81--Merchandised Pkg, Firebird
Y82--Merchandised Pkg, Trans Am
Y84--Merchandised Pkg, Trans Am GTA
Y87--Merchandised Pkg, Performance Enhancement
Z5X--Mirror Provisions, Arabic Language
01U--Primary Color, Exterior Special
1LE--Performance Package, Component Special
1OI--Interior Trim, Arctic White
10Q--Molding Color, Arctic White
10T--Top Color, Arctic White
10U--Primary Color, Exterior Arctic White
11Q--Molding Color, Pewter Metallic
11U--Exterior Color, Pewter Metallic
102--Trim Combination, Leather Arctic White Camaro and Firebird
103--Trim Combination, Leather Arctic White Pontiac
105--Trim Combination, Leather Arctic White Pontiac
14B--Trim Combination, Cloth Dark Gray
14D--Trim Combination, Cloth Dark Gray
14I--Interior Trim, Very Dark Gray
142--Trim Combination, Leather Very Dark Gray Camaro and Firebird
143--Trim Combination, Leather Very Dark Gray Firebird
144--Trim Combination, Leather Very Dark Gray Camaro
20Q--Molding Color, Blue Metallic
20U--Exterior Color, Blue Metallic
28Q--Molding Color, Navy Blue Met
28U--Primary Color, Exterior Navy Blue Metallic
31Q--Molding Color, Bright Green
31U--Primary Color, Exterior Bright Green
36Q--Molding Color, Fern Green
36U--Exterior Color, Fern Green
41Q--Molding Color, Black
41T--Top Color, Black
41U--Primary Color, Exterior Black
52B--Trim Combination, Cloth Light Neutral
52D--Trim Combination, Cloth Light Neutral
52I--Interior Trim, Medium Neutral
522
Trim Combination, Leather Light Neutral
523--Trim Combination, Leather Medium Neutral II
524--Trim Combination, Leather Medium Neutral
56T--Top Color, Medium Dark Neutral
63Q--Molding Color, Sport Gold
63U--Exterior Color, Sport Gold
73B--Trim Combination, Cloth Flame Red
73I--Interior Trim, Flame Red
79Q--Molding Color, Mystic Teal
79U--Primary Color, Exterior Mystic Teal
81Q--Molding Color, Bright Red
81U--Primary Color, Exterior Bright Red
88Q--Molding Color, Bright Purple
88U--Primary Color, Exterior Bright Purple
92B--Trim Combination, Cloth Medium Pewter
92I--Interior Trim, Pewter
96Q--Molding Color, Cayenne Red
96U--Primary Color, Exterior Cayenne Red Metallic
99Q--Molding Color, Hugger Orange
99U--Exterior Color, Hugger Orange
Old Jun 16, 2010 | 11:04 AM
Or you could do it the "hard way" and look at the ratio stamping on your old ring gear.
You could also count the teeth on the r&p gears and do the math.
Old Jun 21, 2010 | 04:13 AM
Dillon5224's Avatar
well just another update
The gears should be here tomorrow and it should be out of the shop hopefully tomorrow or tuesday... or at worst wednesday =(
Next: Getting the car back and how she runs!!
Old Jun 21, 2010 | 08:49 AM
Grandpaswagon's Avatar
PSHAW! That is too much like work.
Old Jun 21, 2010 | 02:48 PM
KissMyTush's Avatar
Originally Posted by craby
alot of guys run the 411 with a m6 and like it. wouldnt want to do it with a m5 or a4.
yeah Blue_thunder01 has 410s in his 01 SS M6 and he loves it! But I agree. I wouldn't put that ratio in a M5 or A4.
Old Jun 21, 2010 | 04:08 PM
I have 4.10s in my 3/4 ton pickup. It is a 6.0 backed with a 4L80E. I'm not sure what the final drive ratios are for the 4L60E and 4L80E are though.
My truck turns about 2100 rpm at 55 mph. Definitely higher than my Z28 which is only about 1400 rpm at the same speed.
Old Jun 21, 2010 | 04:10 PM
KissMyTush's Avatar
RPO Table RPO
Description
D82--Paint Special
NK3
T43--Spoiler, Rear
T79--Lamp, Fog Rear
T96--Lamp, Fog
V76--Hook, Tow
522
Mine's on the inside of my door. Where it shuts right under were the striker and the door connect.
Old Jun 23, 2010 | 06:44 AM
  #20
jjz28's Avatar
I love my factory m6 with 3.42 posi.
baseballer91
VS
11
Apr 17, 2008 08:43 PM
1985RS
May 9, 2007 10:43 PM
