LT1/LT4 Tech 1993-1997
Ground Strap Problem - Getting Really Hot
Old Aug 24, 2012 | 08:34 AM
cdnturboz's Avatar
Default Ground Strap Problem - Getting Really Hot
To give some back ground, I rebuilt the engine on my 95 formula (took engine out through the bottom)
Just finished buttoning up everything last night, pulled the two injector fuses, and the pcm fuse. Cranked over the car a few times to make sure everything is hooked up and as well build some oil pressure.
The car cranked over a few times fine then all of a sudden I see smoke coming from the driver's side front of the car, get out and I am poking around and touch the ground strap that goes from the wiring harness to the driver's front frame rail is so hot you can't even touch it.......
Any ideas on what it could be?
I checked the ground that goes to the block on the passenger's side and it was slightly loose. Would that cause a problem?
Thanks
Old Aug 24, 2012 | 08:40 AM
Yes it would. If the cable to the block wasn't carrying ground, the strap took the load.
That's a lot of amperage draw from the starter for the thin ground strap to handle.
Old Aug 24, 2012 | 08:58 AM
cdnturboz's Avatar
Thanks for the reply, I had tightened that ground last night, but it was late so I haven't tried cranking the car again. I'll try tonight and keep you posted.
Old Aug 24, 2012 | 09:34 AM
Greg08's Avatar
hurrrryyyy
Awsomo 4000
Apr 26, 2012 01:11 PM
BasicConcepts
Aug 12, 2011 11:54 PM
reloadx510
Jun 17, 2010 08:58 AM
Paz
Jan 1, 2009 08:27 PM
camaro girl
Nov 13, 2008 07:44 PM
