Ground Strap
Old Apr 23, 2012 | 01:14 PM
Awsomo 4000's Avatar
Default Ground Strap
Would anyone have an idea where I should begin searching for the ground strap on my 91 with a 305?
I can't find anything from the block to the chassis so I'm wondering if the previous owner took/left it off for any reason.
Old Apr 23, 2012 | 02:34 PM
torque_is_good's Avatar
let's look at the ground
engine block attaches to motor mount, motor mount has metal to metal contact with front frame.
negative battery should have a connection to the body as well as to the engine
since you have iron heads, you'll also find several grounds on the rear of the cylinder heads going to the firewall. If you don't, it's duck soup to make one. A ground wire does not need to be the flat, silver colored thingamajig (that's a technical term)
Old Apr 26, 2012 | 01:11 PM
Thanks Torque. I'll have a look.
cdnturboz
Aug 24, 2012 09:34 AM
BasicConcepts
Aug 12, 2011 11:54 PM
reloadx510
Jun 17, 2010 08:58 AM
Paz
Jan 1, 2009 08:27 PM
camaro girl
Nov 13, 2008 07:44 PM
