good distributor to use
hey does anyone know of a good distributor to use on a 94 z28 i used to have the 500$ msd one but it recently broke so im looking to get a good one at a decnt price.. any suggestions?
delco or delphi, oem style, go to vented if you can
Are they good performance wise??
No worse than an MSD one. They usually last longer and cost less too.
You'll need some actual modifications to use a vented opti...unless you do another version which is basically creating your own vent for the opti and rigging up the vacuum lines.
Delphi and ac delco are essentially the same thing, the MSD I've been told can be a pain since it really has no exact way to set the timing. I recently did mine and went with an aftermarket from CMS which I found is a love/hate thing depending on who you talk to. I purchased mine for around $130 and a year warranty, started up first try and has given me no problems. |
Thanks that's good to know ill ne looking into a them soon. I don't mind the msd and haven't had a huge problem with it but it sat for a while and got water and stuff in it so im just not trying to go broke over a distributor
Originally Posted by JGuy07
(Post 607062)
...the MSD I've been told can be a pain since it really has no exact way to set the timing.
Curious what broke on the MSD? When I compared it to the stock one, the MSD is built like a tank. |
Hmmm, when browsing the forums when I was looking for opti info as well I came across a few ppl talking about MSD opti's and the timing issue. I asked, and they said something about a way to adjust it yet you can never tell where exactly it is set to. A few mentioned theirs was set wrong and timing was off directly out of the box. It was awhile back yet I can't remember if the thread was on here or another forum. Almost impossible to find one that far back about an opti since there are so many threads about them.
computer adjusts the timing. it would take a little time but would end up were its tuned to be. chandlermotorsports is a site sponsor and makes a warented opti. a few of the guys have them and have not had issues.
(Post 607090)
