LT1/LT4 Tech 1993-1997
Front control arm and Spindel
Old May 16, 2007 | 05:14 PM
jaimejames2's Avatar
Default Front control arm and Spindel
Will a control arm and spindel of a 1997 V6 camaro be Ok on a 1997 Z28,V8 camaro?
Old May 16, 2007 | 07:25 PM
Default RE: Front control arm and Spindel
Nether car has spindles, what control arms are you talking about?
Old May 17, 2007 | 01:34 AM
Hi pete maybe it's called an lower control arm or A arm on driver side and the unit where the disc rotor and wheel atach to.
Old May 17, 2007 | 10:46 AM
That is the hub assembly, and is the same on both cars, but there are two types, one for ABS and the other for non-ABS. The front end of these cars have upper and lower control arms connected to the steering knuckle, and the hub is bolted to the knuckle.
grover
Dec 4, 2011 11:45 AM
grabbem88
Sep 26, 2011 02:12 PM
Combat_Chuck
Apr 19, 2008 11:03 AM
doinbout150
Oct 8, 2007 09:32 PM
