Forgot to take pics- Vacuum line connections
So had to replace head gaskets and Ive got the heads, intake, and exhaust manifolds back on. I am having some trouble figuring out where some lines go. they are the smaller dia black hoses. I know I need to connect the diaphram on the back of the intake up but not sure to where and I also have a black plug with two hoses coming from it. It is NOT the one that has a hose that crosses from the passenger side to the driver side under the throttle body.
Any diagrams or close up pics of your engines would greatly help and be appreciated!
its helped for a couple things thanks! Need some help on putting the rockers back on. I beleive valves are EiiEEiiE 1 is farthest from firewall on drivers side? If thats right then the only thing I need is how to know if the #1 is on the firing stroke or not. I cant see the timing marks from above but I took out #1 plug and put a screw driver in it to feel the piston reach tdc. Any way of telling which stroke its on? I know I can see if the rockers moved by feel but I cant turn the engine, hold the screw driver and feel the rockers all at the same time.
http://bellsouthpwp.net/D/T/DTK123/l...adjustment.htm try this site out. als the othe site i putuphas alot of great tips for puttinon the rocker arms and valve adjustments.
so long as your on the valve closed cycle your ok. the setting of the valves when not running does not get it completely correct, it should get you to a running condition so lifters can be set with motor running.
