LT1/LT4 Tech 1993-1997
fans on kick on
Old Oct 16, 2011 | 12:02 PM
dogdog130's Avatar
Default fans on kick on
i just got this camaro and i went to start it up and let it sit and run to get out the old gas it been sitting for like 3 years but the rans wont kick on the fuse is fine the car would get almost to red id turn it off and let it cool and do it again still nothing any ideas
Old Oct 16, 2011 | 12:40 PM
what motor?
Old Oct 16, 2011 | 12:47 PM
JGuy07's Avatar
Craby, is there a way someone could put the setup of the Sig mandatory? As in when creating the profile on the forum the signature page should automatically pop up as part of registering?
As for the fan problem, if fuses and relays are good then check the fan motors directly by jumping them to see if they're good. If they are then you could trace the wiring. Also, if a person were to pull the ECT sensor on the WP the fans should automatically kick on, if no system problems are in the way.
Old Oct 16, 2011 | 01:16 PM
dogdog130's Avatar
lt1 94 z28
Old Oct 16, 2011 | 02:01 PM
Catmaigne's Avatar
Fans kick on at 226 and 235.
Bad fans: Use a 12v battery to jump the fans manually. They aren't very loud until the high speed kicks in at 235.
Bad fuse: Most of the fuses in the fuse box are the same. Switch the fans with the fog lights fuse and check to see if that changes anything.
Bad coolant temperature sensors: There are two sensors, one in the head on the passenger side and one in the water pump. The head temp sender goes only to the gauge cluster. The water pump temp sender goes to the PCM so it can turn the fans on or off when needed.
Old Oct 16, 2011 | 02:59 PM
nope signatures are a personal thing.
Old Oct 16, 2011 | 03:00 PM
could be fuse, fan relay, temp sensor (on the water pump) or bad fans
Mr. Iroc
82-92 V8 Tech
Mar 5, 2012 06:03 PM
NJZ28
Jun 27, 2011 09:37 PM
1979RSGator
Sep 26, 2009 01:30 AM
crazycar350
70-81 V8 Tech
Feb 23, 2009 09:36 PM
irocktheIROC
Oct 27, 2008 10:17 PM
