estimated HP
haha i don't have that. i was thinking of that being my build. but wanted to know what kind of power it would make. i was thinking about 460ish
If you're looking to put 460 to the rear wheels I doubt the 195cc AFR's have the port volume to flow enough for you to get that kind of power. 460 at the crank wouldn't be unheard of though, but a lot of it is going to depend on your cam.
what kind of cam would be good? something that would be powerful but would be smog legal
keepin the car emissions friendly is gonna be difficult. and i also agree wit silver the 195s probably dont flow enough you could go with a bigger heads and a nice custom cam and full bolt ons and you should be close.
You didn't give even close to enough info. Like all posters said, those heads...probobly not the best.
What pistons are you using? Compression? Cam? Timing? Ignition? Intake, carburation? Unless its all quality components and you know what you're doing...Id say 400 at the flywheel or less.
