LT1/LT4 Tech 1993-1997
Error code 41
Old Sep 23, 2025 | 08:26 PM
32rdstr's Avatar
Default Error code 41
Just had an error code 41 pop up on my 1994 Firebird engine. Engine would start just fine and after about 5 seconds it just quits. I noticed that when it quits all the gauges drop to off as if I were losing power (just like turning off the key). I suspect the key switch is the problem. It's an aftermarket market knock off GM switch like fond in older GM dash mounted switches. Question is: why run for a short time and then just shut off? It did clear itself after about 5 starts but don't trust it now. Thoughts?
Old Sep 24, 2025 | 08:52 AM
still getting 41 code? sounds like may betwo issues. test ignition wires for volts if you can get it to fail again.
41 Camshaft sensor – Circuit fault or ignition control – circuit fault/error
Old Sep 25, 2025 | 06:51 AM
32rdstr's Avatar
Problem has gone away and I don't know why! As far as I could tell it was electrical, but can't get it to happen again. Doesn't give me much confidence to set out on a road trip. Where I live leaving town involves lots of desert with NOTHING.
my first camaro
Jan 23, 2017 03:07 PM
B_Dubya
Jul 31, 2015 06:59 PM
mjchris
Feb 11, 2009 10:19 PM
jdubs1813
Jun 1, 2007 08:52 AM
Celticsfan
Oct 2, 2006 05:35 PM
