LT1/LT4 Tech 1993-1997
electrical issues
Old Aug 10, 2009 | 09:23 PM
imcdowel's Avatar
Question electrical issues
yup. more electrical problems with the camaro. its a 1997 lt4. so heres the problem. i know the bulbs work. i had them tested. and when the car locks, they flash, but the actuall front turn signals and fog lights don't work from their switches. which is wierd, the rear turn signals work but not the front ones? why wont they work? why wont the fog lights work either? also, the oil pressure goes crazy on the dash when i hit the gas, what needs to be replaced? AND when i turn right or left my gas gauge goes crazy, it never gives me a real reading? is there a way to read it maybe? like when its telling the real reading? left it goes up right it goes all the way down, when i am going straight, who knows... if not, what needs to be replaced here? i appreciate any help, thanks.
Old Aug 10, 2009 | 09:59 PM
have u taken the cluster out to check the connections and wireing condition or other posible issues under there? could be a bare wire up in the column or bad ground. is the column lose?
Old Aug 11, 2009 | 12:27 AM
imcdowel's Avatar
well i checked the back of the fog light switch and it all looks fine, i suspect i may need a new switch for the fog light. but i havn't tried to get into the steering collumn for fear of the airbag!!! is it safe to get in there? how do do it to look, unless someone has done this befor due to similare problems. i hate taking my car to dealers, i can't see what they do, so they usually lie! than they hand me a bill for a plastic switch for 800$... so if i can juuuust fix this damn light issue...
Old Aug 11, 2009 | 12:28 AM
imcdowel's Avatar
oh, the cullumn is not loose as far as i can tell, nor do any wires if yoiu pull apart easy to reach plastic.
Old Aug 11, 2009 | 02:28 AM
ok never know if someone has wired in a stereo or car alarm and damge wires. check all your fuses under the hood and in inside the car? gettin late cant think anymore. lol.
tattoo400
Jul 17, 2012 01:17 PM
Eagle564
Apr 21, 2012 09:58 PM
KirschFamily97
Nov 10, 2011 09:02 PM
pistolpete_67
Jul 9, 2006 02:14 AM
Thirdgenfan8289
Jan 24, 2006 04:57 AM
