LT1/LT4 Tech 1993-1997
Droping the motor...what to buy
Old Nov 13, 2011 | 12:10 AM
jrgearhead's Avatar
Default Droping the motor...what to buy
Okay so im going to get the motor out and have my heads and intake ported and a different cam. I have almost 120k miles should i re do the lower end while im at it? And if so what do you guys recommend for all of that? The money isnt really in the budget but i could save a little more in order to get it. Thanks
Old Nov 13, 2011 | 07:34 AM
what was your oil pressure at operating temp? compression test should give you some indicators as to the condition of your rings.
Old Nov 13, 2011 | 11:39 AM
You could develop a ring blow-by condition after tightening up the heads, as the rings would now become the weak link in holding cylinder pressure.
Old Nov 13, 2011 | 12:15 PM
jrgearhead's Avatar
ill check the pressure but how good is our stock bottom end? will it hold up to more power for much longer?
Old Nov 13, 2011 | 12:18 PM
BasicConcepts's Avatar
Technical User
Now is a perfect time to replace those motor mounts
Old Nov 13, 2011 | 04:29 PM
stock bottom end is good to 400 to 450 hp so long as your not using nos or forced air.
dopez28
Nov 13, 2011 04:25 PM
dopez28
Oct 16, 2011 11:11 PM
sebi1990
Sep 28, 2010 11:26 AM
