LT1/LT4 Tech 1993-1997
Dirty orange spark..
Old May 29, 2011 | 08:31 PM
iCrossbone's Avatar
He bought a new opti 3 times already.
Old May 29, 2011 | 09:15 PM
try taking off all the plug wires from the cap and drying them and the cap plugins. dry the coil wire as well. take the plug wires off the plugs and dry them. the water will stay for quite some time if it gets in any of the connectors. check the plugins on your pcm/ecu for any water and if theres an inspection plate on it open and check for water. on any of these, use a little electrical grease on em if you have any when putting back together. helps to seal them and its easier to get them off next time.
Old May 29, 2011 | 10:09 PM
iCrossbone's Avatar
Ill tell him.
Old May 30, 2011 | 12:34 AM
iCrossbone's Avatar
He said this: New opti. Plugs. Wires. ECM ..electronic spark contol module. Cap. Ignition coil. Map sensor. Etc. Everything is new. It gets spark after the opti. But it's just a real weak orange. And doesn't have enough to start it.
Old May 30, 2011 | 12:50 AM
wow and all these parts are new after the water bath? what brand name opti? if you have access to a checker for peak voltage, test the voltage at the coil wire and a couple plug wires.
Old May 30, 2011 | 11:42 AM
iCrossbone's Avatar
ill tell him.
AmericanMuscle1989
May 4, 2013 09:37 AM
cbr600rx7
Jul 16, 2009 05:36 PM
Dancj2
Apr 24, 2006 05:32 AM
