LT1/LT4 Tech 1993-1997
delete air pump
Old Oct 20, 2009 | 11:11 PM
95slvrZ28's Avatar
If I was at all interesting in removing it I could probably figure out an electrical spoof. I doubt the computer looks for much more than a change in resistance on a line, but I could be wrong.
You can get the code tuned out of your computer. If you're looking to free up space I would consider it, but as stated before, you're not going to free up any HP.
Old Oct 20, 2009 | 11:17 PM
I'm sure that's all the computer is registering. It certainly doesn't know whether the air hoses are connected or not.
If you don't mind hopping on that right away and getting back to us on what works as a spoof, that would be greatly appreciated. Is tomorrow by lunch time good for you?
Old Oct 21, 2009 | 12:18 AM
r6rider's Avatar
well i have to get my motor tuned anyway and the less cluttered the engine bay looks the happier i am even tho its on the bottom and you really cant see much of it.
Old Oct 21, 2009 | 01:43 PM
95slvrZ28's Avatar
I think I already missed it
Honestly though, I'll take a look around later this evening to see if I can dig anything up.
Old Oct 22, 2009 | 02:11 PM
sm515's Avatar
fyi my 93 didnt didnt trip the ses light/ fans. but i have seen that when i unplugged the coolent temp sensor. maybe the earlier years were different. try it....
Old Oct 22, 2009 | 02:52 PM
CNCman's Avatar
Camaro 69 is right, I removed the Air Pump, CAT, and EGR got the PCM re-programmed and the fans come on about 20 sec after cranking it and will not go off.
Just got it running and have not had time to find out why the reprogram didn't fix that. Thanks Camaro 69 , I didn't know about the Air Pump turning them on, so that helps to trouble shoot the problem ! The reprogram was was suppose to address the Air Pump removal. The SES light does not come on, and i changed every sensor on the engine with new ones.
Old Jun 11, 2013 | 02:00 PM
Sicilian's Avatar
Um not to highjack this tread but I just took the 3.4L motor out and put it back in, at no point did I see anything remotely close to AIR pump, but I have no codes shown..... I'm confused as to where it could be, or do I have this on my motor?
Old Jul 3, 2013 | 01:22 PM
9434V6's Avatar
some 3.4s dont have it. i think the camaros in general for the 3.4l dont have one since my last 2 and anything in the junkyard didnt have one, but i noticed the 3.4 birds do have one.
CarolinaCamaro
Jan 18, 2015 08:28 AM
dopez28
Jul 2, 2010 07:26 AM
maroman209
Nov 6, 2007 02:28 PM
camarohelp
Sep 8, 2007 05:38 PM
twiz
82-92 V8 Tech
Jul 21, 2007 12:27 AM
