LT1/LT4 Tech 1993-1997
Dead in the Water: Transmission Woes
Old Mar 27, 2011 | 05:00 AM
x01660's Avatar
The Mustang Hunter
Unhappy Dead in the Water: Transmission Woes
Vehicle: 1995 Z28 M6 'vert
Problem: I was on the freeway doing 60. I wanted to pass someone, so I attempted to shift into 5th. I went into reverse. Now, I have accidentally done this in the past, or rather, it would grind and I would put it in 5th. This time, it seems like it went in, and then I lost all drive to the car.
When stopped, I can put the car into any gear without depressing the clutch. It also has no drive in any of the gears. My question: Is it the clutch, the shift linkage, or something else?
I have no leaks and the trans case is intact. There weren't any grinding noises either. Any help or advice would be appreciated. Thanks.
x01660
Old Mar 27, 2011 | 06:18 AM
GLENN M's Avatar
ouch!
Old Mar 27, 2011 | 11:24 AM
Massey's Avatar
sounds like you have internal damage. Remove the trans and open the case to see your shrapnel, most likely you have broken the output shaft.
Massey
Old Apr 24, 2011 | 09:23 PM
x01660's Avatar
The Mustang Hunter
Talking The T56 is pretty indestructible
My T-56 Lives!!!!!
Turns out that I completely grenaded the clutch, but the trans is ok!!!
Got the clutch kit on order, will be here on Tuesday. I will upload pics of the clutch a little later!!
BOWTIES FOREVER!!!!
Long live the Silver Bullet!!
x01660
Old Apr 26, 2011 | 07:20 PM
x01660's Avatar
The Mustang Hunter
Default Pics
Here are the pics of my clutch:
New clutch is here. I am gonna put it in this evening.
x01660
Old Apr 26, 2011 | 08:21 PM
Oh nice. If I can offer just a little piece of advise...don't throw it in reverse while going forward, at any speed!
That should be a sticky.
Old Apr 26, 2011 | 10:56 PM
oh heck a little welding and its good as new. lol.
Old Apr 27, 2011 | 02:26 AM
x01660's Avatar
The Mustang Hunter
Default She lives!!!
Clutch is in and it works.
Question: The clutch pedal seems to be closer to the ground than it was. Any ideas on how to adjust it, or is that just the way a new clutch is? Thanks.
x01660
Old Apr 27, 2011 | 07:56 AM
could be al little air in it. try pumping the hech outa the clutch. like a thousand times.
Chia219
70-81 Transmission & Differential
Sep 26, 2012 10:16 AM
CrimsonRevolver
Feb 25, 2012 06:32 AM
Marty
Sep 4, 2009 01:16 PM
ike728
May 21, 2009 07:17 PM
