LT1/LT4 Tech 1993-1997
Dead Fuse?!
Old Nov 16, 2006 | 04:16 AM
Veritas's Avatar
Default Dead Fuse?!
So I’m about to get the 94z I’ve been asking about, and supposedly the day I test drove it both the passenger and driver windows stopped working along with the drivers seat (all electric).
Is that a burnt fuse or what? I didn’t have the time to check it out then but will try tomorrow. You guys have any other Ideas of what might be causing it?
Appreciate it,
-Jake
Old Nov 16, 2006 | 12:44 PM
uncle bill's Avatar
Default RE: Dead Fuse?!
If all the windows / seats quit at the same time, it's probably a fuse.
Old Nov 16, 2006 | 05:57 PM
Veritas's Avatar
K I'll check it out, Its still in the guys shop so I'll have to take a look at it tomorrow, thanks
Old Nov 16, 2006 | 09:47 PM
The 94's had problems with the window switches themselves. If you still have the original swithch, you may want to teake a good look at it. The circuit is protected by a circuit breaker which automatically resets.
Old Nov 17, 2006 | 09:11 PM
Veritas's Avatar
I tried changing the fuses, didnt work... when I tried to lower the passenger side window it sounded as if it was trying to god down but didnt... as for the drivers seat... no sound or nuthin just plain doesnt move.
Old Nov 18, 2006 | 01:36 AM
I took a quick look at the wiring diagram and the seats and windows appear to be fed from different circuit breakers (not fuses), so it seems odd that they both should break at the same time. May want to check the fusible links, but then a whole bunch of things will go out at one time.
camaro468
Aug 16, 2012 01:56 PM
izayuhgawd
Nov 21, 2011 09:24 PM
ladybridgeport
Apr 5, 2010 08:44 PM
