Cut out?
RE: Cut out?
After the exhaust manifold or header, instead of going to the traditional exhaust system, there is a "y" pipe installed. On one of the "legs" of the "Y" connects to the traditional cat back style exhaust and the other "leg" is blocked but can be opened so the exhaust gases can bypass the full exhaust system.
RE: Cut out?
and also it will make your car roar like crazy lol sounds really good you dont need stereo to be intertain lol love the sound of it, but the side effect is in ur wallet it drains the gas too quick lol
RE: Cut out?
I got the factory tail pipes and i was told that if you put some big round tail pipes ur sound is a bit louder dunno. I've hear that it gives 10hp if so.. mm you can get it online http://www.lmperformance.com/2898/2.htmlcheck that website out, and if you want to go even more check out the manual openers when ever u want to u can just open the valve with a hit of a button check it out.
http://www.speedunlimited.com/cgi-bi...09107564772.56
RE: Cut out?
ORIGINAL: carguylt1
you can get cut outs that are controled with a cable. the only thing is they wont hold back pressure on the o2 sensors so your car wont realy run right.
