LT1/LT4 Tech 1993-1997
Custom cam from Lloyd
Old May 16, 2011 | 08:50 PM
MaVeN's Avatar
Default Custom cam from Lloyd
If you have an auto and no stall, I would go with a 222/226 .571/.566 110 LSA cam. If you are willing to use a stall, we could go even larger.
This will need good springs like the Patriot Gold Extremes ($265 thru me).
$300 for a custom cam.
Old May 16, 2011 | 08:51 PM
MaVeN's Avatar
Oops. Is this a good cam? I know Lloyds the expert. Just wondering.
Old May 18, 2011 | 11:40 PM
i would say its the largest cam he felt comfortable recomending that would work without a stall converter. i have run mine with the stock converter and it was a pain. had to switch to the 52mm tb to get the idle low enough so it wouldnt drag me through the gravel with front brakes sliding. once i got it set up it worked ok. much better with the stall.
carid
Vendor Special Buys
Oct 31, 2014 05:42 AM
bobshannon22
May 16, 2011 11:43 AM
z28rob18
Sep 13, 2008 10:15 AM
2fast4u
Jan 23, 2007 11:15 PM
94CamaroSFI
Dec 3, 2006 04:13 PM
