LT1/LT4 Tech 1993-1997
Crank hub?
Old Dec 30, 2012 | 12:43 AM
Mikey.'s Avatar
Default Crank hub?
Hey guys. I had a pretty bad wobble on my harmonic balancer. I replaced it, and there's still a small wobble. I think I have to replace the hub. My question is.. where the heck do I find it?
I've checked ebay and my local part stores. I found two online. One is keyed, and my balancer is not. The other one looks kind of odd and is also keyed..
Any ideas?
Old Dec 30, 2012 | 09:24 AM
Before wasting any more money, pull your hub off, run the engine, and look to see if the crank snout itself is wobbling.
Some nit-wits have been known to jack up the front of the engine by the lower pulley, and then bending the crank.
Old Dec 30, 2012 | 10:03 AM
wow 76 bucks,,, #10128273 GM Parts Direct: Your direct source for Genuine GM Parts i dont think the keyway makes a difference., at least the one i bought said it worked with either.
Old Dec 30, 2012 | 11:36 AM
Mikey.'s Avatar
Oh wow. No part of this motor has seen a jack. I'm not that dumb. lol
This is a new problem. I've had the car for over a year now. Still think it's a possibility?
And thanks Craby. I might buy the one they have on Jegs.
Old Dec 30, 2012 | 09:57 PM
Wasn't referring to you...but a previous idiot!
"This is a new problem"...what does this mean, what was the tip off? Did you just start to experience a vibration, or do you not have a vibration at all? Is it possible you always had a wobble, but just now noticed? Crank hubs don't just "bend" on their own. Seriously, save your money for now till you remove the hub and inspect the crank.
Old Jan 12, 2013 | 08:38 PM
Mikey.'s Avatar
Still haven't messed with the crank hub, been pretty busy lately.
I have an odd question though. My car has the newer version of the optispark with the piece that has two o-rings that go into the cam. When I was replacing it the oring on the top got messed up. I peeled it off and stuck it in. I'm wondering if this could cause the vibration that I'm getting. From what I read it stabilizes that shaft. Interested in what you guys think.
tbl76camaro
Jan 21, 2011 06:10 PM
9t4Z28
Apr 15, 2009 08:26 PM
Rfalker1
Dec 25, 2008 08:18 PM
camarohelp
Jul 17, 2008 09:52 PM
gotalcoholmanup
May 16, 2007 12:59 PM
