LT1/LT4 Tech 1993-1997
couple problems.. advice would be great.
Old May 6, 2007 | 02:05 AM
defender6's Avatar
Default couple problems.. advice would be great.
bought a 96 z28 today, havent had much time to really look it over yet, but when im driving the car seems to pull to the left, i thought it was the alignment, but shortly afterwards i realized it also pulls to the left, and if i hit a bump or get on an incline it pulls to the side aswell.. Is this due to my front suspension? what all should i check for?
any help would be greatly appreciated.
[IMG]local://upfiles/6493/13124233779B44899D1B119F5E44C855.jpg[/IMG]
Old May 6, 2007 | 02:43 AM
Default RE: couple problems.. advice would be great.
You need to take a good look at everything involved is supension(front & back)and steering. Things such as ball joints, tie rod ends, steering rack, bushings, shocks, tires, brakes, alignment, and even subframe bolts. What your car is doing is usually caused by worn out or loose parts. You should have a goos front end shop take a good look at it & see what they suggest.
Old May 6, 2007 | 12:03 PM
defender6's Avatar
ok thanks for the info.
MS69 YENKO/4-SPEED
Apr 6, 2015 09:40 AM
carlocamaroVA
Feb 2, 2013 12:12 PM
kyleag89
Dec 11, 2008 03:37 PM
Bigrob92rs
May 12, 2006 04:38 PM
