LT1/LT4 Tech 1993-1997
Correct Scat Crank?
Old 06-06-2011, 09:01 PM
NorthernCrew454's Avatar
Default Correct Scat Crank?
Would this be the correct scat crank for a stock stroke rebuild?
SCAT Engine Components 435010L - Scat Forged Standard Weight Crankshafts - Overview - SummitRacing.com
Rear Main Seal Style: 1-piece
Engine Stroke (in): 3.480 in.
Crankshaft Material: Forged 4340 steel
Engine Balance: Internal/External
Balance Style: Neutral
Rod Journal Diameter: 2.100 in.
Old 06-07-2011, 08:39 PM
greenmachine96's Avatar
It looks right. Pretty sure it should work as long as its one piece rear main seal, i believe. The measurements are right.
jshblue8907
05-03-2014 07:57 PM
NorthernCrew454
08-06-2013 07:27 AM
NorthernCrew454
05-01-2011 09:35 PM
Jville_hot_skate
03-18-2009 04:55 PM
theFLoYD1964
01-07-2008 10:26 PM
Quick Reply: Correct Scat Crank?
