LT1/LT4 Tech 1993-1997
cooling fan problem
Old Jan 29, 2012 | 09:11 PM
shypes3's Avatar
Default cooling fan problem
I've been trying to diagnose my cooling problem for months. I put a new coolant temp sensor in, and still no luck. The fans won't work at all. Also tried relays and fuses. When I unplug the cts the fans run, but they run all the time. I heard someone talking about a auto trans fluid temp sensor and that the ground for the cts runs to that. Has anyone heard of an atf temp sensor? Could this be my problem? Thanks.
Old Jan 29, 2012 | 09:22 PM
BasicConcepts's Avatar
Technical User
Old Jan 29, 2012 | 09:40 PM
Catmaigne's Avatar
The fans come on at 226 for low speed and 235 for high speed. Your car should bounce between 230 and 210 while sitting at idle. There are two coolant temp senders; One is in the water pump and relays info to the PCM and the other is in the head and only controls the engine temperature gauge. If you unplug the WP temp sender or run the A/C (assuming your A/C works and hasn't been disabled by the low pressure cutoff switch) then the fans will run all the time. The fact that your fans run when you unplug the WP sender says to me that your fuses and fan motors are good. How hot does your car get? It's not overheating until it gets to the red zone.
Old Jan 29, 2012 | 10:20 PM
shypes3's Avatar
I ran it up to the red and the fans never kicked on.
Old Jan 29, 2012 | 10:40 PM
Catmaigne's Avatar
The fans did run when you unplugged the pigtail for the WP sensor so that rules out the fuses, motors, and power. Sounds like the WP sensor is faulty or maybe even the PCM is bad, but that's highly unlikely. Pull the temp sensor and test it with a multimeter at room temp.
Taken from Shbox.com:
ECT Temperature vs. Resistance Values
ºC -- ºF -- Ohms
35 -- 95 -- 1802
30 -- 86 -- 2238
25 -- 77 -- 2796
20 -- 68 -- 3520
15 -- 59 -- 4450
10 -- 50 -- 5670
5 --- 41 -- 7280
0 --- 32 -- 9420
Old Jan 30, 2012 | 06:42 AM
also look at number 12 here 4th Gen LT1 F-Body Tech Aids
Old Jan 30, 2012 | 05:57 PM
shypes3's Avatar
Ok, I have a phantom car. I posted another thread about the car not starting. I fixed that, plugged the ECT back in. Now everything is working perfect. Glad its fixed but I'm stumped on the problem to begin with. Mabey a loose/pinched wire. Who knows... Thanks for all the helpful advice guys!
Old Jan 30, 2012 | 08:09 PM
Technical User
no problem buddy
gville4life
Apr 7, 2010 11:27 AM
heath3800
Jan 9, 2010 10:59 AM
mr porky
82-92 V6 Tech
Sep 15, 2007 06:27 PM
02blackonblack
Aug 16, 2007 04:01 PM
92camsilboat
Apr 30, 2006 10:11 PM
