LT1/LT4 Tech 1993-1997
Cooling fan...
Old Apr 17, 2008 | 08:29 PM
robmnrd's Avatar
Default Cooling fan...
What is it (thing)that goes wrong, or brakes, or short circuits, or dies, or whatever, which causes the cooling fan to come on prematurely?
Often times my fan will come on at start up, even in the dead of winter. If it doesn't come on right away, it comes on after five or so minutes. It comes on, and switches on/off. I don't think I've ever seen the temp get above 160 (Though that may actually be a good thing. lol.).
I could have sworn that some circuit or connection goes kapoot, and that's the cause, but I can't remember exactly what.
As always, I appreciate any and all help.
P.S. I searched for 45 seconds...then got lazy. lol.
Old Apr 17, 2008 | 11:54 PM
95slvrZ28's Avatar
Default RE: Cooling fan...
Do you know if the car has had a new thermostat put into it? 160 deg thermostats are the "aftermarket" one to install, just a thought.
Other than that, are you getting an SES light when the fan comes on?
Old Apr 18, 2008 | 02:37 PM
robmnrd's Avatar
Is there an easy way to check for said thermostat? Does the dash thermostat indicator change?
Nope, no SES light. I wish it would come on though, I'd take to a shop faster than you can say bleh!
Old Apr 19, 2008 | 03:23 PM
robmnrd's Avatar
Bump?
Old Apr 19, 2008 | 03:30 PM
02StanGT's Avatar
Try looking at the ECT (Engine Coolant Temperature) sensors, if your fans are on all the time, and temp stays low.
bizarre660
82-92 V8 Tech
Nov 9, 2014 08:32 PM
ok.f-body
May 29, 2009 12:03 AM
superROB23
Aug 13, 2007 05:59 PM
1994Z
Feb 13, 2007 10:35 PM
SbC89CAMARO
Nov 30, 2006 09:33 PM
